Router Audit Tool
Jan 25th, 2009
I chanced upon this tool on the internet some days back and have been trying to use it without any success.I have looked everywhere without any troubleshooting documents as well.I have installed Active Perl as well as the RAT on the C drive as follows with the default unstallations. C:\Perl and C:\CIS. I have a sample configuration file called SampleIOSConfig.txt in the path C:\CIS\RAT\etc\configs\cisco-ios as well as the local.conf file. The rat.exe is in the pathC:\CIS\RAT\bin\ .When I run C:\CIS\RAT\bin\rat -r local.conf SampleIOSconfig.txt, I get this message:
C:\>CIS\RAT\bin\rat -r local.conf SampleIOSConfig.txt
No configuration files available to audit at rat line 897.Yet,when I put the files in the temp directory and run I get it run successfully as shown:
C:\>cd temp
C:\Temp>C:\CIS\RAT\bin\rat -r local.conf SampleIOSConfig.txt
auditing SampleIOSConfig.txt...
Parsing: /local.conf/
Checking: SampleIOSConfig.txt
done checking SampleIOSConfig.txt.
ncat_report: writing SampleIOSConfig.txt.ncat_fix.txt.
ncat_report: writing SampleIOSConfig.txt.ncat_report.txt.
ncat_report: writing SampleIOSConfig.txt.html.
ncat_report: writing rules.html (cisco-ios-benchmark.html).
ncat_report: writing all.ncat_fix.txt.
ncat_report: writing all.ncat_report.txt.
ncat_report: writing all.html.
C:\Temp>
How do I get it run correctly?
Any assistance please
xhackuss1 Fri, 01/30/2009 - 01:24
Thanks Eddie. I have already tried nipper. I is very easy to use.The only prolem I have with nipper which I am still investigating is why it gave me a report that my 3750 switch had ssh port open when infact,the IOS doesn't support ssh.
Any idea how I can get accurate results from an audit?
