Cisco Attendant Console w/ CUCM 7.0(1)
Answered Question
Dear all,
I found the following in Cisco Documentation : Cisco does not support the Cisco Unified Communications Manager Attendant Console with new installations of Cisco Unified Communications Manager 7.0(1).
What is the alternative for that?
What can I use if I want to have an attendant console?
Correct Answer by phillip-wright about 8 years 3 months ago
These are thrid party systems but can be purchased through Cisco.and yes you will need a server. you can prchase a Dell, HP etc no need to buy a MCS type.
Yes, you can purchase Unified Department Attendant Console Description
Supports up to 150 directory names and 2 consoles (operator clients) per department. Maximum number of departments is 5. PC Server required.
or
Unified Business Attendant Console Description
Supports up to 500 directory names and 2 consoles (operator clients).
or
Arc Enterprise Solution Plus Description
Supports up to 100,000 directory names and 100 consoles (operator clients).
I hope this helps
Overall Rating: 4 (2 ratings)
phillip-wright Mon, 01/26/2009 - 06:59
What you read was correct, but if you upgrade to 7.0(1) from an earlier version your previous AC will still work.
Correct Answer
phillip-wright Mon, 01/26/2009 - 07:40
or
or
I hope this helps
