Nicholas Matthews Mon, 01/26/2009 - 05:33
Hi Ahmed,
CME supports multiple SIP trunks, yes. In sip-ua, you can only define one sip server though. CME will only register with one trunk - this may limit you from using more than one provider.
If your provider does not require for you to register then you can support as many trunks as you want via dial peers:
dial-peer voice 1 voip
destination-pattern ipv4:1.1.1.1
session protocol sip
dial-peer voice 2 voip
destination-pattern ipv4:2.2.2.2
hth,
nick
youssef.ahmed Mon, 01/26/2009 - 06:31
Hi nick,
Thanks for your reply but does SIP trunk supports more than one audio or video call over it.?
Nicholas Matthews Mon, 01/26/2009 - 06:46
Yes, you can have as many as you can get with the CPU / memory, which will be many hundreds of calls.
hth,
nick
youssef.ahmed Mon, 01/26/2009 - 07:11
Hi nick,
could you explain this statement in more details plz:
"In sip-ua, you can only define one sip server though. CME will only register with one trunk "??
youssef.ahmed Mon, 01/26/2009 - 07:35
Sorry,
But you mean register my router as a SIP gateway to provider's SIP registrar server?
Correct me if i am wrong.
youssef.ahmed Mon, 01/26/2009 - 08:00
Sorry,
Nicholas Matthews Mon, 01/26/2009 - 08:14
Most SIP providers require for your gateway to register one or more numbers.
Our gateways at this time are limited to registering to one registrar only.
If you have a SIP trunk that does not require you to register your number, then you can have multiple.
youssef.ahmed Mon, 01/26/2009 - 07:57
Hi nick,
youssef.ahmed Mon, 02/02/2009 - 23:14
Hi nick,
So i attached my conf.,is there any missing config i should do.
Tandberg endpoint can call me but i can't,i got fast busy with "unknown number"
status,
