SSL VPN Mobile clients
Jan 26th, 2009
We would like to check for PDAs OS in pre-login? Is this possible?
As I remember this was possible on VPN Concentrator, but now when we are migrating to ASA I can't find this possibility.
Marko
Overall Rating: 4.5 (2 ratings)
ggilbert Mon, 01/26/2009 - 06:16
Marko,
I checked the CSD OS check on the latest version of code 3.4 and its not possible to do an OS check for PDA's
In the concentrator code, there was an option for Windows CE to enable Web Browsing and File Access. There was no option for PDA OS check. Please correct me if this is wrong or am I missing something.
Cheers,
Gilbert
mtrcek Mon, 01/26/2009 - 06:34
Thank you for reply.
Well I can't remember exactly, but my customer says that there were option for Mobile OS, but now when you said Windows CE, I think that you are right.
Marko
ggilbert Mon, 01/26/2009 - 07:08
Marko,
Thanks for the response. I did look into the Anyconnect client Pre-login policy issue. The option will be there probably in the next release of the CSD.
Cheers,
Gilbert
