Cisco NAC Framework: Trend Micro OfficeScan v8 & ACS SE v4.1
Jan 26th, 2009
  • Bronze, 100 points or more
I need your help regarding integrating Trend Micro OfficeScan v8 to Cisco ACS server v4.1. I managed to add the OfficeScan server to Cisco ACS but during the posture check, the logs says - Posture validation rule=NAC-POSTURE-RULE; 'Trend:AV:APT=Healthy' returned by: Policy=TRENDMICRO-OFFICESCAN Rule=Default Rule resulting from error 'Posture Validation Failure on External Policy'; 'Cisco:PA:APT=Healthy. I just set the default policy returned posture token by the policy server to HEALTHY if it cannot contact the Trend Micro so that users will not be place to Quarantine which will be having limited access.
Kindly refer to attached files for the captured screenshots.
Thank you.
