ICM custom functions
Is anybody using any custom functions in ICM?
I want to build a function that outputs a particular skillgroup's LoggedOn value but I want to be able to pass the name of the SkillGroup via a variable.
i.e.:
Set Call.PeripheralVariable2="SomeSkillGroup"
Set Call.PeripheralVariable6="SkillGroup."&Call.PeripheralVariable2&".LoggedOn"
If Call.PeripheralVariable6<1 then
some action.
david.macias Mon, 01/26/2009 - 08:33
I love custom functions and use them all the time. You shouldn't have any problem doing what you're trying to do.
In the set variable node do the following:
customfunction(skillgroup), then do the comparisons you wish to do.
david
david.macias Mon, 01/26/2009 - 08:57
Create a new function userTest with 1 Parameter. Then in the Definition:
concatenate("SkillGroup.",%1%,".LoggedOn")
Now in a Set Variable node put PV2 = userTest(MySkillGroup) and upon execution PV2 = SkillGroup.MySkillGroup.LoggedOn
Now, I've not tested this, so let me know if it works.
david
This is what I'm doing but I don't know if is right.
Custom Function:
Parameters: 1
Defenition:
On Script:
Node1: Set Variable
Call.PeripheralVariable2 = "VoiceOps"
Node2: Set Variable
Call.PeripheralVariable6 = userTest1(Call.PeripheralVariable2)
Node3: If
True --> Translation Route
False --> Label
thanks for your help
david.macias Mon, 01/26/2009 - 11:27
Yeah, that looks right. You're using too many PVs, but shouldn't matter for what you're trying to do.
david
david.macias Mon, 01/26/2009 - 11:57
Try value() around the concatenate() function. What does the real time data tell you? You're sure that the name of your skill group is SkillGroup.VoiceOps.LoggedOn?
david
Edward Umansky Tue, 01/27/2009 - 09:53
Don't concatenate it's not a string. Type it directly like this with no quotes:
SkillGroup.%1%.LoggedOn
Edward Umansky Tue, 01/27/2009 - 11:07
You're right, this won't work the way you are attempting. That function would expect a symbol as a parameter and call variables are passed as strings. What you are attempting to do is convert a string object into a symbol. As far as I know there is no way to do this in ICM. You will need to use some IF nodes (or the if function) or a route select to test your call variable setting and branch to the appropriate skill group variable.
david.macias Tue, 01/27/2009 - 11:20
This might do what you want:
Function:
userFunction Parameters: 1
%1%>0
In the script have an if node that has userFunction(SkillGroup.VoiceOps.LoggedOn).
david
