01-26-2009 07:24 AM - edited 03-15-2019 03:46 PM
I have ordered 3 pri's from my telco and they are asking me this question but I am not sure what this means. I know for sure we don't want to do NFAS signaling.... Unless i am not understanding what NFAS really does...
"Exception Please confirm configuration,Order is requesting 3 spans as NFAS no backup D, Cisco builds are usually configured as FAS. Thanks"
Solved! Go to Solution.
01-26-2009 07:27 AM
You probably don't want to run NFAS. FAS is the opposite of NFAS, so you would want that.
NFAS increases complexity and you are also forced to use H323/SIP. You save a couple of B channels at the expense of it being a true pain for implementation.
Your experience may vary.
hth,
nick
01-26-2009 07:27 AM
most usually NFAS is not ordered. in any case read this to understand NFAS
Configuring NFAS with Four T1s
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a00800a6bf2.shtml
java
if this helps, please rate
01-26-2009 07:27 AM
hth,
nick
01-26-2009 07:34 AM
Yes I have used NFAS in a different location and it was really a pain to setup. I am running MGCP on this gateway so I should tell them that I want each PRI setup with FAS signaling... Is that correct?
01-26-2009 08:12 AM
Correct!
Thanks for the kind ratings.
-nick
