Vulnerabilities Apache ciscoworks LMS2.5
Jan 26th, 2009
Hi to all,
The security department of my customer site ran a Vulnerability test on the LMS server and they found this:
Level High
Apache Speculative Mode Denial Of Service
Apache mod_ssl Plain HTTP Request DoS
Level Medium
Apache 1.3.x Multiple Vulnerabilities
Apache Environment Variable Conf File Buffer Overflow
CHARGEN service (Simple TCP Services on Windows) - REMOTE
Apache mod_alias and mod_rewrite Buffer Overflow
Is there a patch or a procedure that I can perform in order to fix this vulnerabilities???
Thanks in advance for your help.
Joe Clarke Mon, 01/26/2009 - 09:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You'll need to upgrade to LMS 2.6 SP1 first. Once there, you will be eligible for the upcoming Apache 1.3.41 update (fix for CSCsx09107). LMS 2.6 can be downloaded from http://www.cisco.com/cgi-bin/tablebuild.pl/lms26 , and the SP1 components can be downloaded from within Common Services > Software Center > Software Update.
