Analog Timeout
Jan 26th, 2009
Connected inhouse PA system to ATA386 box
to provide analog line. Current system is
CCM 3.3(2). Connection works.
Problem is that analog line drops after about 10 seconds. It appears to be timing out. If so, need to increase this
timeout time, does anyone know how to do
p.krane Fri, 01/30/2009 - 08:55
What firmware is the ATA running on? Is it using h323 or sip? Are you having problems with outbound calls only or inbound as well?
greggswitzer Fri, 01/30/2009 - 12:21
Version: v3.0.0 atasccp (Build 031210A)
ProductId: ATA186I1
Features: 0x00000000
HardwareVersion: 0x0006 0x0000
It is strictly a virtual number in the system. It's only connection is to a
PA system in a production area. No calls coming in.
