FAX on UC520
Answered Question
Jan 26th, 2009
I have a UC520 system with a PRI. How do I get a fax machine connected and configured to support inbound and outbound faxes?
The PRI has 100 DIDs and '99' is going to be used for the fax. The fax is plugged into FXS port '0'.
Correct Answer by Nicholas Matthews about 8 years 3 months ago
voice service voip
modem passthrough nse codec g711u
dial-peer voice 1 pots
port 0
destination-pattern 99
That's about it. You will need to adjust your 'port' command to which 'voice-port' it corresponds to, like 1/0, 0/0/0, etc.
Make sure 'show controllers t1' doesn't have any slips/errored seconds.
hth,
nick
Overall Rating: 5 (1 ratings)
Correct Answer
Nicholas Matthews Mon, 01/26/2009 - 10:26
  • Red, 2250 points or more
voice service voip
port 0
hth,
nick
