01-26-2009 09:03 AM - edited 03-06-2019 03:39 AM
Hi all
If I have 2 e1 lines and want to run eigrp on them, would I create a loopback on the router, then give the physical interaces ipunnumbered loopback 0, then multilink them, would eigrp see them as 1 link on the other side ?
01-26-2009 09:46 AM
Hello Carl,
almost correct but if you create a PPP multilink all L3 configuration goes under interface multilink:
int ser0/0
no ip addr
enc ppp
ppp multilink 1
int ser0/1
no ip addr
enc ppp
ppp multilink 1
int multilink 1
enc ppp
ppp multilink 1
ip address unnumbered loop0 | ip address x.x.x.1 255.255.255.252
personally I would give an ip address to the multilink on both sides using an ip subnet /30.
to be able to build EIGP adjacency when using ip unnumbered loop0 some more tuning may be needed
Hope to help
Giuseppe
01-26-2009 11:19 AM
hi
can you tell me why the command ppp multilink 1 is in the multilink interface?
also why would it need tuning? do you mean putting a bandwidth statement on the loopback interface?
01-26-2009 11:28 AM
Hello Carl,
the correct part of my post is that you need to use the multilink interface and you cannot bundle and at the same time assign an ip address (directly or via ip unnumbered ) to member links
about tuning, my concerns are about the capability to build the EIGRP adjacency if the loopback ip addresses are not in the same subnet (if you use /32).
For this reason I recommend to give an ip address to the multilink that is a setup I've already used successfully
for PPP multilink see
the key commands are
ppp multilink
and
ppp multilink group group-number
in this my example on the fly is wrong
Sorry for this
Hope to help
Giuseppe
