Problem with IPSEC tunnel between two Cisco Router 2811
Jan 26th, 2009
I'm trying to set up a site to site vpn from a remote office to a central office with two Cisco 2811 routers. In the remote office there is a non-Cisco cable modem and router (owned by an ISP- Public IP 62.33.44.55 - not real)
The central router is working ok and have other vpn tunnel active.
The router owned by the ISP has the ports redirected to Cisco 2811 router (10.100.100.20 )(UDP 500, TCP 1723, TCP 47, TCP 50, TCP 51).
Tunnel is up, but line protocol is down and I can't make it work.
Configuration is attached.
thanks for any help
regards
Ivan Martinon Tue, 01/27/2009 - 08:53
  • Cisco Employee,
Can you tell us what is the problem? is the tunnel not coming up? Are you not passing traffic? You might want to get rid of the crypto map on the tunnel interfaces of each router and leave only the crypto on the physical interfaces.
