Problems with VPN-Client 5.0 instoled on Windows Vista over ADSL Conecction
Jan 26th, 2009
Hi, I have severals clients that they use Windows Vista and connects throw there lan over a VPN-Client. The clients that has an ADSL connection in there hose has disconect problems. Do you know why?? Do you know same workarround to do?? Thanks.
Regards.
drolemc Mon, 02/02/2009 - 14:56
  • Silver, 250 points or more
Make sure that you have the right cable pinout and that your ISP has turned on the DSL service. Troubleshoot the DSL connection by watching the modem state of the ADSL interface as the line retrains.
To use the VPN Client, you need
- Direct network connection (cable or DSL modem and network adapter/interface card), or
- Internal or external modem
For further more troubleshoot click this link,
http://www.cisco.com/en/US/docs/security/vpn_client/cisco_vpn_client/vpn_client500_501/release/notes/51client.html#wp1550392
