Rebooting multiple access points with WCS?
Jan 26th, 2009
What is the best way to reboot multiple access points using WCS? We use WLAN Override to manage SSIDs on our access points, but we need to reboot access points whenever we change the template. Unfortunately, most of the access points are using power injectors, so this isn't easily done from the switch.
Overall Rating: 5 (1 ratings)
lpswearing Tue, 11/02/2010 - 11:56
There is not a checkbox option for rebooting in WCS templates for me.  I know it was there at some point, because I've used templates before for just what you're talking about. Any ideas?
Trending Topics - Security & Network
