Replacing Failed PIX 525 Primary
Jan 26th, 2009
I need to replace our Primary PIX 525 and have not be able to find any documentation regarding how to do this. Has anyone here ever done thins and if so can they either give me a few suggestions on the best way to go about replacing the PIX or point me to the correct documents?
Jon Marshall Mon, 01/26/2009 - 11:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
James
You should be able to do this fairly easily. Power the primary down and the standby should be active. Make sure your new pix has the same code of PIXOS and the same ASDM/PDM if you are using it and then configure the new pix as you would a secondary pix, see this link -
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#sec
then power up the new firewall. It should sync it's config from the standby and then if needed you can force the failover back to the new firewall as primary.
Jon
jamesdanielkirk Mon, 01/26/2009 - 12:00
jon,
That does sound like what I thought would be the best way to do it. I have copies of the IOS and ADSM to copy to the new unit. Thaks for your help
Jon Marshall Mon, 01/26/2009 - 12:06
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
James
No problem, hope it goes well.
Jon
