creating gre tunnel
carl_townshend
Hi all
Can anyone tell me how to create a simple gre tunnel between 2 routers? also under what circumstances would it be best to use a gre tunnel ?cheers
Carl
9 Replies 9
ryabutler
I like to configure GRE (mainly with DMVPN configuration) to allow dynamic routing and multicast for example to work. Building standard VPN tunnels creates virtual interfaces, which lacks with providing some of those capabilities.
Here is a simple GRE configuration ...
>> R1
interface FastEthernet0/0
interface FastEthernet0/1
ip address 192.168.10.1 255.255.255.0
interface Tunnel0
ip address 10.10.10.1 255.255.255.252
tunnel source FastEthernet0/0
tunnel destination 192.168.1.2
router eigrp 1
network 10.10.10.0 0.0.0.3
network 192.168.10.0
no auto-summary
>> R2
ip address 192.168.1.2 255.255.255.0
ip address 192.168.20.1 255.255.255.0
interface Tunnel0
ip address 10.10.10.2 255.255.255.252
tunnel destination 192.168.1.1
router eigrp 1
network 192.168.20.0
no auto-summary
vishwancc
Level 3
Level 3
Hi Carl:
Gre Tunnels are used if you want to use dynamic routing protocol,multicast etc.
IPsec do not support dynamic routing .
http://www.ciscosystems.com/en/US/tech/tk86/tk89/technologies_configuration_example09186a008011520d.shtml
Chao
Vishwa
gauravbisht
Hi Carl,
GRE tunnel is used when you want to send your management traffic over your tunnel (i.e routing protocol updates or other routing information.)
Router1 connecte to internet via FastEth0/0
Router2 connected to internet via FastEth0/1
(Router1)<---->(internet cloud)<---->(Router2)
Router1--Fa0/0=10.0.0.1/30
Router2--Fa0/1=50.0.0.1/30
Step1: Create tunnel interface.
Step2: Assign ip address to tunnel interface.
Step3: configure tunnel source ip.
step4: Configure tunnel destination ip.
Step5: Specify tunnel mode(Optional GRE is default)
Router 1 configuration
#conf t
(config)#int tunnel 1
(config_if)#ip address 1.1.1.1 255.255.255.252
(config_if)#tunnel source 10.0.0.1
(config_if)#tunnel destination 50.0.0.1
(config_if)#tunnel mode gre
Router 2 configuration
#conf t
(config_if)#ip address 1.1.1.2 255.255.255.252
(config_if)#tunnel source 50.0.0.1
(config_if)#tunnel destination 10.0.0.1
But GRE tunnel not provide any enctyption or hashing.
your can use authentication by giving command in tunnel interface
(config_if)#key Cisco#234
key should be same on both tunnels end here example is Cisco#234
Fore more security you can use IPSec over GRE tunnel.
hi there, can someone please give me a sistutation or example of when youwould need to use them, im still not aware why they are needed
thanks
hi
can anyone help with this?
thanks
Hi Carl
the tunnel interfaces are used as described above to run dynamic or static routing or bundling links between routers.
also tunnles keepalives are commanly used to overcome the black holes caused by certain type of connections when they still up while the link has mideway problem in L1 or L2.
1 more point to be clear is you can configure the tunnle interfaces between routers that are not directly connected so you can run dynamic routing between them and bypath any intermdiate hops
i am still unsure why people would need them, can anyone elaborate on this, ie give a situation when I would need one ?
Carl,
For GRE without the IPSec, let's say you have a remote site that is connected via a dedicated circuit by your service provider and you don't want to share routing tables with the provider, but still want to provide routing for your remote site. With perhaps just a static route to the tunnel destinations on each router you can provide full routing for your remote site through the GRE tunnel.
I'll give another example. We have MPLS connectivity among our regional offices and home office. We route traffic over that using BGP. However, our carrier does not support multicast traffic over BGP over MPLS, yet we need to send multicast traffic to our regional offices. Hence, GRE tunnels to each.
