Inline power module issue
Jan 26th, 2009
Are the following modules supported in Cisco 4006 with SUP (WS-X4013)? or do I have to configure anything for power to work?
WS-X4548-GB-RJ45
WS-X4548-GB-RJ45V
I have just installed them but I'm not able to power up an ip phone through their ports. Module is recognized in the switch and data vlan works fine.
Overall Rating: 4 (1 ratings)
nawas Mon, 01/26/2009 - 14:20
Eidion
That means that the module WS-X4548-GB-RJ45V I have will work only in Cisco 4500, correct?
So the only solution is either I upgrade my SUP module to supV or get the PEM and DC power shelf? Can you please clarify?
Edison Ortiz Mon, 01/26/2009 - 15:21
  • Hall of Fame,
    Founding Member
Best investment will be upgrading the chassis as the 4000 Series chassis is already end-of-life.
Your current Sup will work in a 4500 chassis and it will support the PoE modules provided you equip the chassis with the appropriate power supply to power up the modules.
Go to Cisco Power Calculator http://www.cisco.com/go/powercalculator for power supply recommendation.
HTH,
__
Edison.
