Dial-peer question (sending 15 and 16 digits)
Jan 26th, 2009
I have a need to send both 15 and 16 digits (including 011 and country code) to Germany. The issue I am running into is that when the user gets to the 15th digit it gets sent since it matches the dial peer with 15. How do I get them to both be viable? I cannot use the 9T since we have a security need to lock down certain patterns.
sticano Mon, 01/26/2009 - 13:30
dial-peer voice 50 pots
description Germany
destination-pattern 901149..........
port 0/3/0:23
forward-digits 15
dial-peer voice 120 pots
description Germany
destination-pattern 901149...........
port 0/3/0:23
forward-digits 16
Jaime Valencia Mon, 01/26/2009 - 13:47
  • Cisco Employee,
  • Hall of Fame,
    2011
add as last digit T to the one for 15 digits so it expect for more digits
destination-pattern 901149..........T
java
if this helps, please rate
sticano Mon, 01/26/2009 - 13:48
do I take out the forward-digits command? Will the 9 get stripped out?
Kenneth Mohammed Mon, 01/26/2009 - 13:52
  • Silver, 250 points or more
Remove the forward-digits and add prefix 011
Hope that helped, if so please rate.
sticano Mon, 01/26/2009 - 13:56
So just to clarify:
description Germany
port 0/3/0:23
prefix 011
However, forward-digits 0 gets inserted.
Kenneth Mohammed Mon, 01/26/2009 - 13:59
Try adding prefix 011 and forward-digits all.
Nicholas Matthews Mon, 01/26/2009 - 13:56
  • Red, 2250 points or more
Since you have overlapping dial plans you will have to wait for the interdigit timeout. This means you will have to use the T keyword after your 15 digit dial peer.
This is slightly different from the way that CUCM routes calls, as the gateway will send it as soon as there is a match rather than wait for the longest match.
hth,
nick
