Power enable SSM module
Answered Question
Jan 26th, 2009
I have shutdown the ASA SSM module with
hw-module module 1 shutdown
How can I power it on again.
Correct Answer by Jon Marshall about 8 years 4 months ago
Hardware reset means the ASA SSM module will actually reboot itself rather than just reload the software.
You can't use "hw-module module 1 reload" because the SSM module needs to be up for this command to take effect. As you have shut the module down it won't respond to the reload option.
A reset does not set the config back to default or anything. What a reset does is simply a shutdown followed by a restart.
Jon
Overall Rating: 5 (1 ratings)
cisco_lite Mon, 01/26/2009 - 15:21
But this would perform a hardware reset. I am not sure what all is included in the hardware reset, probably configuration or license loss.
I just need a reboot/power on command.
Correct Answer
Jon Marshall Mon, 01/26/2009 - 15:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
