01-26-2009 02:39 PM - edited 03-06-2019 03:39 AM
If I have a user that "accidentally" sets his IP address the same as our gateway, will:
a) It bring the network down or will the router gracefully continue to work?
b) configuring DAI on the 3750 that I have keep this from happening?
c) or is there another way of dealing with this?
We are strictly DHCP, so DAI might be the way to go, but are there other methods?
Thanks!
John
Solved! Go to Solution.
01-26-2009 02:44 PM
John
a) Well you will probably get very intermittent connectivity depending on which mac-address the end client registers for it's default-gateway
b) DAI is a possible solution. Never used it myself but from what i understand about it yes it could be used to determine valid mac-address/IP address pairs.
c) Last place i worked users could not change the IP address ie. the Windows profile did not give them the option of changing the IP address.
A user could still bring in their own laptop but you could combine c) with machine authenication ie. 802.1x.
Jon
01-26-2009 02:44 PM
John
Jon
01-26-2009 02:49 PM
Thanks Jon :)
John
