RSPAN
Jan 26th, 2009
  • Bronze, 100 points or more
Hey Guys,
We have an IPCC server in our data centre which is connected to our core switch. Our core switch is then connected into a router which connects back to our central site's router. They want to be able to use call monitoring and RSPAN was mentioned but I dont think we can use it as the switching domains are separated by routers. Is this correct?
Cheers,
Ross.
Kerem Gursu Tue, 01/27/2009 - 00:18
Hi Ross,
You can not use RSPAN when the switching domains are seperated by the routers.
Kerem
Jon Marshall Tue, 01/27/2009 - 00:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ross
You are right in that RSPAN cannot run over a routed network. However ERSPAN can do this. Of course ERSPAN is not available on all switches -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/span.html#wp1059482
Jon
