Joe Clarke Tue, 01/27/2009 - 09:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Very basically, it means the startup and running configs are out of sync. That is, there are changes in one configuration which are not in the other. Typically, this occurs because one makes a configuration change, but does not do "write mem".
If you do a Sync in RME, then RME will sync the two configs with a write mem operation.
