877 Router DSL connectivity issues
c.walsh
Level 3
Level 3
I am trying to configure an 877 on my home network in the UK. I have just switched provider to 02 as they will let me use my 877 router & Sky would not. However they do not support the cisco router & are not very helpful with information re the config. I am having issues with IP connectivity, layer 1 is fine & i can do an ATM ping no problem. It appears to be a PPP negotiation problem, but the only info i can get from them is that the username & password should be blank. I have been assigned an IP address, but have also tried configuring the dialer interface for "ip address negotiate".
When i do a show ip int brief, all interfaces are UP UP, except for virtual-access2 that is UP DOWN. Any ideas??
5 Replies 5
paolo bevilacqua
Send relevant config, and output of "debug ppp neg" with "term mon".
Sorted it now, FYI i have attached the config.
version 12.4
no service pad
hostname Cisco877W
boot-start-marker
boot-end-marker
enable secret xxxxxxxx
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 syslog
dot11 ssid Cisco877W
authentication open
guest-mode
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.200.1 192.168.200.5
ip dhcp pool dpool1
import all
network 192.168.200.0 255.255.255.0
dns-server 94.192.119.254 87.194.0.51 87.194.0.66
default-router 192.168.200.1
ip name-server 87.194.0.51
ip name-server 87.194.0.52
ip name-server 94.192.119.254
username colinw privilege 15 secret 5 $1$YMNI$.G2vd.6qw6Lo1b7yUgQgi0
archive
log config
hidekeys
bridge irb
interface ATM0
mac-address xxxx.xxxx.xxxx (mac of 02 router)
no ip address
ip virtual-reassembly
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description ADSL2+ o2broadband
ip address x.x.x.x x.x.x.x
ip nat outside
atm route-bridged ip
pvc 0/101
oam-pvc manage
encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption key 1 size 128bit 0 xxxxxxxxxxxxx transmit-key
encryption mode wep mandatory
ssid Cisco877W
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip nat inside
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
ip address 192.168.200.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip http server
no ip http secure-server
ip nat inside source list 102 interface ATM0.1 overload
access-list 102 permit ip 192.168.200.0 0.0.0.255 any
no cdp run
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
transport input telnet ssh
scheduler max-task-time 5000
end
So in O2 terms "blank user/pw" means "no PPP is used" - nice to know :)
It has taken me ages to work that one out, hopefully this config will help someone else.
Certainly it does and I've rated your post.
