LMS Disk Space issue .
Jan 27th, 2009
Hi ,
We have LMS 3.1, windows version . Previously it was holding 300 devices license . Recently we have added 500 more devices license .
But now we are facing an issue in the Disk space . We observed there is very less free space only in the C: and D :Drive .
Now it is continuously giving en error message as less disk space and could not do anything with that also .
Can anyone please clarify my below doubts .
1) Can I upgrade the disk space by adding additional hard disk ?
2) If so should I go for complete installation or not ?
Thanks and Regards ,
Joe Clarke Tue, 01/27/2009 - 09:43
1. Yes provided you're using some kind of logical volume manager which allows adding more physical disks to a logical pool.
2. If you don't have an LVM, then you will need to do a reinstallation from scratch onto a new disk. Once that is done, you can restore the backup from the previous installation to get all of your data back.
