communication with citrix
Jan 27th, 2009
i needed to allow users to be able to connect to a remote citrix server. After allowing all the ports on my firewall, the port status is still showing blocked. below is an extract of my config
access-list outside_access_in extended permit tcp any eq citrix-ica any
access-list outside_access_in extended permit udp any eq 1604 any
access-list outside_access_in extended permit tcp any eq 2598 any
how can i get this thing to work.
Jithesh K Joy Tue, 01/27/2009 - 03:25
The above access-list will not allow you to initiate a citrix connection. please try the following.
access-list outside_access_in extended permit tcp any any eq citrix-ica
access-list outside_access_in extended permit udp any any eq 1604
access-list outside_access_in extended permit tcp any any eq 2598
lomuwagun Tue, 01/27/2009 - 05:49
thks. Just tried your solution but its not going trough. if i use port scan, i still receive the message that the port is closed.
hunnetvl01 Tue, 01/27/2009 - 07:07
Something else:
How do you use the port scan>
Did you check that there is no windows firewall enbled on the PCs?
