DB replication status in CUCM. What steps should I use to restore relica?
Answered Question
Jan 27th, 2009
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_2/ipchange/ipchg612.html
Information from link:
<i>
Be aware that the Replicate_State object shows a value of 2 in this case. The following list shows the possible values for Replicate_State:
-0-Replication Not Started. Either no subscribers exist, or the Database Layer Monitor service is not running and has not been running since the subscriber was installed.
-1-Replicates have been created, but their count is incorrect.
-2-Replication is good.
-3-Replication is bad in the cluster.
-4-Replication setup did not succeed.
</i>
What should I do, when I get numbers 1,3,4 on RTMT or with CLI
show perf query class "Number of Replicates Created and State of Replication"
Correct Answer by Jaime Valencia about 8 years 5 months ago
1) Run stop on all nodes that will be reset. Stop CLI will stop any currently running processes and give us a clean slate to restart replication.
2) Go to each server (that will be reset), get on the CLI, and run. "utils dbreplication stop"
3) On pub, run the "utils dbreplication stop" as well.
4) Then, (also on the pub) run "utils dbreplication reset all" command (to reset replication on the pub and ALL Subs.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 01/27/2009 - 04:09
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Jaime Valencia Tue, 01/27/2009 - 06:19
  • Cisco Employee,
  • Hall of Fame,
    2011
step 1 just refers to running the command utils dbreplication stop on all servers to avoid anything from a previously running process
java
Tommer Catlin Tue, 01/27/2009 - 14:31
  • Green, 3000 points or more
Before going to the reset DB extreme, simply reboot Publisher, then reboot the Subscriber and recheck the RTMT status for DBs. I had a Publisher that must have came up before a subscriber after a power outage or something. The PUB had a bad number, I rebooted it everything went to 2 + 2 4
