Starting Meet-me from ATA
Jan 27th, 2009
Is it possible to initiate the meetme fonction from a phone which is connected to ATA device ?
Overall Rating: 4 (1 ratings)
Jaime Valencia Tue, 01/27/2009 - 04:32
To activate: Off-hook, and enter **5 At the prompt, enter the Conf-Bridge number.
java
if this helps, please rate
Jonathan Schulenberg Thu, 01/29/2009 - 18:07
Is this unique to FXS ports or would this work for third-party SIP devices that do not have a MeetMe soft key as well?
Jaime Valencia Thu, 01/29/2009 - 20:25
this is fot SCCP devices, that code generates the necessary event even if not available via a softkey.
java
