Cisco 2800 + NME-CUE + NM-HDV2-2T1/E1
Jan 27th, 2009
could you help to find wich model of cisco router 2800 can support both card ( NME-CUE + NM-HDV2-2T1/E1)
Many thanks in advance
Hicham
Overall Rating: 5 (1 ratings)
paolo bevilacqua Tue, 01/27/2009 - 05:28
  • Hall of Fame,
    Founding Member
All the models but the 2801. Note, you can take the VWIC2 and PVDM2 from the NM-HDV2, and put them directly on the motherboard. This way, you will save a NM slot.
