Error when opening Unity 5.0 Telephony Integration Manager
Jan 27th, 2009
  • Gold, 750 points or more
Hello All,
we are getting an error message when trying to open UTIM. It seems to correlate with bug ID CSCsi54038. The first suggested workaround is not an option. The second workaround did not seem to work although there was a 2 week gap between the execution and the needed reboot. We have a seperate Unity cluster not having this problem with the same version of Unity but the OS is on Service pack 2 whereas the OS on the problem cluster is on SP 1. That's the only real difference between the 2 clusters.
As you can see by the attached file we are getting a message that says the account has to be a member of the admin group, etc. but the account does have all teh required rights and memberships.
Thanks in advance! All replies rated
