VPN Issue
stephen.stack
Level 4
Level 4
Hi Guys,
Hope someone can help here.
We have a cite-to-site tunnel established as per the config below. And someone on these forums recommended the config as a primary/backup VPN.
crypto map outside_vpn 11 match address VPN-TO-CUST
crypto map outside_vpn 11 set peer CUST_ENDPOINT_A
crypto map outside_vpn 11 set transform-set strong
crypto map outside_vpn 12 match address VPN-TO-CUST
crypto map outside_vpn 12 set peer CUST_ENDPOINT_B
crypto map outside_vpn 12 set transform-set strong
Now, the primary VPN works fine. A remote host can ping the external interface of our firewall over the VPN when VPN-A is up.
When VPN A fails, VPN-B is built. But this Tunnel will only accept traffic and will not transmit.
I get the following error.
Denied ICMP type=8, code=0 from 10.39.10.194 on interface Outside
IKE Initiator unable to find policy: Intf Outside, Src: x.x.x.x, Dst: 10.39.10.194
Where x.x.x.x is the external IP.
Please help me fix this problem?
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
9 Replies 9
Ivan Martinon
Level 7
Level 7
Stephen, when the secondary tunnel kicks in, who starts this tunnel? AFAIK the router having 2 Peers should be the one that should start the tunnel, as well I would advise you to use the same crypto config with only adding a second peer:
crypto map outside_vpn 11 set peer CUST_ENDPOINT_B
using this type of configuration you tell the router to use the second peer when the primary is not responding, with the configuration you have above, the router wil always try to use peer A
thanks for the response.
I just treid this conf and i get the message below.
ERROR: Multiple Peers can be specified only with originate-only connections
I have also tried the whole origintae only commands and this is not working to good for me either. Appears to failover to other tunnel but kinda goes up and down a lot.
Any other idea? Desperate now :(
Stephen
You got me there, something I was not recalling, I believe that unfortunately routers do not have the option of setting the direction of the crypto map, you might want to review your design and go for GRE/IPSec solution.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/P2P_GRE_IPSec/2_p2pGRE_Phase2.html
Ok, but the ASA does not do GRE tunnels... does it?
Nope, but you never mentioned ASAs on the picture ;) where is it located?
OMG, what a plonker... so sorry. I should have said form the outset. Located?
By located I mean is it one of the remote peers? is it the central peer?
HI,
sorry for the delay in getting back to you on this. It appears that the config you first gave me does not work on asa7.2(2). But does on 7.2(3)
It is working great now.
blackmichael
I just had the same issue run 7.2(2).  I upgraded to 8.0(4) and had no problem entering in the second peer.
So the answer is 7.2(2) cant do it .... Upgrade!!!
