Data extraction question - LMS 3.1
Answered Question
Jan 27th, 2009
Why is duplex setting is not included in IF_Entry data when extracting data through the API?
Correct Answer by Joe Clarke about 8 years 5 months ago
I don't know of any plans. I have filed some bugs requesting that the DEE exports match the DDR (and most have been added in RME 4.2). However, since duplex is not even in DDR, those bugs don't apply. Yes, I would suggest you raise this as an enhancement.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 01/27/2009 - 11:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This isn't stored in the RME database. Only speed is stored. As for why this information isn't stored by inventory, it was most likely an oversight.
sirbaughmf Wed, 01/28/2009 - 09:15
Do you know if there are plans to add it? If not would you suggest putting in an enhancement?
Correct Answer
Joe Clarke Wed, 01/28/2009 - 09:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
