BRI France Telecom
Jan 27th, 2009
I have 2 CCME in Frans.
With 4 BRI.
I tried to set-up these BRI.
The BRI receive and can place call, but disconnect/reconnect all the time.
On a sh isdn status, most of the time, when there isn't any call, the layer 1 is deactived.
I have other CCME in other countries, and no problem, the layer 1/2 is always up...
I tried with statis tei, dynamic tei, ...
The best result is with tei negotitation first-call, with that, I can place call if the layer 1 is down, that automatically activate it.
But at the end of the call, the BRI is disconnected.
It's on 2 different site, and FranceTelecom has tested the lines, all is ok.
The only think I know from FT is that it's ISDN of type Numeris+.
Is it possible to keep these BRI up ?
Thx
Paolo Bevilacqua Tue, 01/27/2009 - 09:37
  • Hall of Fame,
    Founding Member
Hi, everywhere in Europe BRI layer 1 is brought down by the CO after a timeout. You cannot change this behavoir.
In consequence of that, the best setting is "isdn tei negotiation preserve". You also need to configure
network-clock-participate WIC x
network-clock-select 1 BRI x/y
repeat this for all ports in decreasing priority.
If still problems, post you configuration and the exact IOS used.
dufour001 Mon, 02/23/2009 - 06:08
I tried like this.
And also tried with negotiation at first call.
All is good except when I use callforward feature.
With this, I receive the call, CCME try to forward the call (to an external num), and that fail.
opn Q931 debug, I see that the call is rejected.
If I reswitch to static tei, all is good.
Paolo Bevilacqua Mon, 02/23/2009 - 06:15
  • Hall of Fame,
    Founding Member
When there are multiple BRIs in huntgroup, it's always static tei, sometime telco calls this "PBX".
nonosensei Fri, 05/29/2009 - 06:22
Did you find the solution?
I have a trunkgroup with 4BRI and only inbound calls work well.
could you send me your configuration? It will be a great help for us ?
thanking you in advance,
Paolo Bevilacqua Fri, 05/29/2009 - 13:58
  • Hall of Fame,
    Founding Member
He was using a standard configuration:
I tried like this.
Please mention the IOS you are using.
Paolo Bevilacqua Thu, 10/22/2009 - 07:21
  • Hall of Fame,
    Founding Member
Already replied in another thread, please open new thread about new problem (beside, I think you had asked this already).
