Installing 2nd WIC card in Cisco 2811 router
Jan 27th, 2009
I'd like to know the proper procedure for installation, please. Does it require the router to be powered off? Any help would be appreciated.
Best regards.
lf
Tshi M Tue, 01/27/2009 - 08:43
  • Silver, 250 points or more
here is a short step:
1. issue the "sh diag" to verify the slot
2. configure card type "card type t1 slot# where slot# is the one return from sh diag.
regards,
angelmed Tue, 01/27/2009 - 12:25
Thank you your help...I can't use "card" command though, not sure if it's because of IOS ver?:
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 21:09 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 19 weeks, 1 day, 2 hours, 59 minutes
System image file is "flash:c2800nm-ipbase-mz.124-3i.bin"
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FTX1234A0QF
2 FastEthernet interfaces
1 Serial interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Is it necessary to use this command?
thanks
paolo bevilacqua Tue, 01/27/2009 - 12:34
  • Hall of Fame,
    Founding Member
Only for T1/E1 cards.
Tshi M Tue, 01/27/2009 - 12:44
I am not sure but it should work with ver 12.4
Are you issuing the command from the config mode? what do you get from sh diag?
angelmed Tue, 01/27/2009 - 12:57
I have not installed 2nd WIC card yet; I have WIC-1DSU-T1-V2 card already installed in WIC slot 0, for the existing T1 line.Still I can't use "card" command, so I'm afraid that I will not be able to make proper configuration for additional T1 line..
sh diag
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : FOC12323XKT
Hardware Revision : 1.0
Top Assy. Part Number : 800-26920-04
Board Revision : A0
Deviation Number : 0
Fab Version : 04
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20080809
Chassis Serial Number : FTX1234A0QF
Chassis MAC Address : 0022.904d.8088
MAC Address block size : 24
CLEI Code : COM7R00ARA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-05
Version Identifier : V05
--More-- EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 32 33 32 33 58 4B 54 40
0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 41 30
0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 68 A9 C2 8B 46 54 58 31 32 33 34
0x40: 41 30 51 46 C3 06 00 22 90 4D 80 88 43 00 18 C6
0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
WIC Slot 0:
FT1 PMC4351
Hardware Revision : 1.2
PCB Serial Number : FOC122941SD
Part Number : 73-8346-05
Board Revision : A0
RMA History : 00
Deviation Number : 0-0
Product (FRU) Number : WIC-1DSU-T1-V2
Top Assy. Part Number : 800-22193-03
CLEI Code : IPUIAPRRAA
0x00: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 31 32 32
0x10: 39 34 31 53 44 82 49 20 9A 05 42 41 30 03 00 81
0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 57 49 43
0x30: 2D 31 44 53 55 2D 54 31 2D 56 32 20 20 20 20 20
0x40: 20 C0 46 03 20 00 56 B1 03 C6 8A 49 50 55 49 41
0x50: 50 52 52 41 41 FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
paolo bevilacqua Tue, 01/27/2009 - 19:28
  • Hall of Fame,
    Founding Member
That is a T1 only card and you don't need to enter card type command
angelmed Wed, 01/28/2009 - 06:22
Thank you to all who responded to my question.
lf
