Restricting ccmhelpdesk access
Jaime Valencia Tue, 01/27/2009 - 08:55
CUCM??? ALWAYS mention what you use
if so not with MLA, MLA grants access to menus and provides a security level of view only, change but is not granular to the level of which DNs you can view an account
if this helps, please rate
testeven Tue, 01/27/2009 - 08:56
Not sure what's the exact CCM version you have. If it's a 4.X version you can use MLA or if it's 5.X or later you can confifure roles and user groups to restrict access to admin users.
Check these links:
** Multilevel Administration Configuration **
*** Cisco Unified Communications Manager System Guide, Release 6.1(1) ***
--> Roles and User Groups
Have a nice day!
Jaime Valencia Tue, 01/27/2009 - 09:07
MLA doesn't go that far, i believe there is a 3rd party solution that could do this. i cannot find it right now but you can try searching NetPro as it has been posted previously
