PIX 6.3.3 Failover problem - been working for months
Jan 27th, 2009
I have a pair of 525 PIX's running 6.3.3 (old I know, downtime preventing upgarde/hardware swap out) that just decided to start throwing failover errors.
I saw this in the logs at the time of the failure:
Jan 23 18:26:34 elm-pix-2 Jan 23 2009 18:26:34: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface 1
Jan 23 18:26:34 elm-pix-2 Jan 23 2009 18:26:34: %PIX-1-105008: (Secondary) Testing Interface 1
Jan 23 18:26:45 elm-pix-1 Jan 23 2009 18:26:45: %PIX-1-103005: (Primary) Other firewall reporting failure.
Then after getting to the unit and unplugging and reconnecting the failover cable, I saw this:
Jan 27 09:20:47 elm-pix-2 Jan 27 2009 09:20:47: %PIX-1-101004: (Secondary) Failover cable not connected (other unit)
Jan 27 09:20:51 elm-pix-1 Jan 27 2009 09:20:51: %PIX-1-101003: (Secondary) Failover cable not connected (this unit)
Jan 27 09:21:17 elm-pix-2 Jan 27 2009 09:21:17: %PIX-1-101001: (Secondary) Failover cable OK.
Jan 27 09:21:21 elm-pix-1 Jan 27 2009 09:21:21: %PIX-1-101001: (Primary) Failover cable OK.
Jan 27 09:21:37 elm-pix-1 Jan 27 2009 09:21:37: %PIX-1-709003: (Primary) Beginning configuration replication: Send to mate.
Jan 27 09:21:51 elm-pix-2 Jan 27 2009 09:21:51: %PIX-1-709006: (Secondary) End Configuration Replication (STB)
Jan 27 09:21:51 elm-pix-1 Jan 27 2009 09:21:51: %PIX-1-709004: (Primary) End Configuration Replication (ACT)
Jan 27 09:23:37 elm-pix-1 Jan 27 2009 09:23:37: %PIX-1-709003: (Primary) Beginning configuration replication: Send to mate.
Jan 27 09:23:51 elm-pix-2 Jan 27 2009 09:23:51: %PIX-1-709006: (Secondary) End Configuration Replication (STB)
Jan 27 09:23:51 elm-pix-1 Jan 27 2009 09:23:51: %PIX-1-709004: (Primary) End Configuration Replication (ACT)
So I can then do a wr standby on the primary BUT I DO NOT see the 'starting to sync', and I get this from the 'sh failover'......failover config below as well:
ELM-PIX525-1(config)# sh fail
Failover On
Cable status: Normal
Reconnect timeout 0:00:00
Poll frequency 15 seconds
failover replication http
Last Failover at: 09:14:49 CST Fri Mar 28 2008
This host: Primary - Active
Active time: 26707815 (sec)
Interface outside (65.166.254.2): Normal
Interface inside (10.200.1.249): Normal
Interface EDMZ1 (172.30.1.1): Normal
Interface EDMZ2 (0.0.0.0): Link Down (Shutdown)
Interface MGT (10.200.1.125): Link Down (Waiting)
Interface intf5 (172.27.0.1): Normal
Other host: Secondary - Standby (Failed)
Active time: 0 (sec)
Interface outside (65.166.254.3): Normal
Interface inside (10.200.1.250): Normal
Interface EDMZ1 (172.30.1.3): Normal
Interface EDMZ2 (172.31.1.3): Link Down (Shutdown)
Interface MGT (10.200.1.126): Link Down (Waiting)
Interface intf5 (172.27.0.2): Normal
failover
failover timeout 0:00:00
failover poll 15
failover ip address outside xx.xx.254.3
failover ip address inside 10.200.1.250
failover ip address EDMZ1 172.30.1.3
failover ip address EDMZ2 172.31.1.3
failover ip address MGT 10.200.1.126
failover ip address intf5 172.27.0.2
failover link intf5
Thanks for any help....
Chris Serafin
[email protected]
eddie.mitchell@... Thu, 01/29/2009 - 09:57
If the configuration hasn't changed at all, it might be a hardware issue with one of the interfaces on the secondary unit. If you do a 'sh int' on the secondary unit, do you see a large number of errors on any of the interfaces?
Is the state interface (intf5) directly connected on both units or is it going through a switch?
Hope this helps.
