WS-C6509 crash
Jan 27th, 2009
I' ve a cisco WS-C6509 with a SUP-1A and a MSCF2 and a PFC.A Catalyst running Catos 5.2.1 version via xmodem download, but the system crashed after It finished to complete the System Power On Diagnostics.
Can you help me ?
Mark Yeates Tue, 01/27/2009 - 09:22
That definitely appears to be software issue. Verify that you have loaded the correct software to the supervisor and it meets the minimum RAM requirements. If it does I would try to use a more recent version of catOS and see if that fixes the problem. If that doesn't work I would recommend putting in a TAC case for further assistance.
