01-27-2009 09:17 AM - edited 03-06-2019 03:40 AM
6509
SUP720-3BXL
IOS 12.2(33)SXH2a
when i do a show int tranceiver details i get the "Diagnostic Monitor Data is not available" Is there something that I need to turn on?
01-27-2009 09:33 AM
Which transceivers are you using? If I remember correctly it will only show transceivers that have digital optical monitoring (DOM) enabled. This means that you have to have transceivers that support the DOM capability to use the "show interface tranceiver" command.
HTH,
Mark
01-27-2009 09:36 AM
SFP type. I am not sure the exact model as they are whatever shipped from cisco. I will physically check
01-27-2009 10:00 AM
GLC-SX-MM
