HSRP Issue
Jan 27th, 2009
Hello All,
I have an HSRP issue. Here's the st standby brief output from my switches.
switch 1
Vl501 51 100 P Active local 172.25.10.253 172.25.10.1
Vl600 60 100 P Active local 172.25.11.253 172.25.11.1
switch 2
Vl500 50 95 P Standby 172.25.10.253 local 172.25.10.1
Vl501 51 95 P Standby 172.25.11.253 local 172.25.11.1
switch 1
ip dhcp pool Vlan501
network 172.25.11.0 255.255.255.0
domain-name vlan501.local
default-router 172.25.11.1
dns-server 159.18.161.34 66.51.99.55
lease 2
switch 2
lease 2
The issue is that, the second switch is giving out the IP addresses from DHCP pool rather than the first router.
Any help would be appreicated.
OJ
Roberto Salazar Tue, 01/27/2009 - 10:00
  • Gold, 750 points or more
NOt sure why this is an issue both of the routers/switch are doing dhcp server. dhcp request from clients are bcast, naturally if switch gets a request from clients, it will try to assign ip address, it's a dhcp server after all. What is the real issue?
sarahr202 Tue, 01/27/2009 - 14:58
  • Bronze, 100 points or more
switch 1
switch 2
Vl500 50 95 P Standby 172.25.10.253 local 172.25.10.1 ( hsrp group should be 51 not 50)
Vl501 51 95 P Standby 172.25.11.253 local 172.25.11.1 ( hsrp group should be 60 not 51)
default-router 172.25.11.1 (it should be 172.25.10.1)
switch 1
vlan 501 is on 172.25.10.0 not on 172.25.11.0
