01-27-2009 10:27 AM - edited 03-15-2019 03:48 PM
Can someone please give me some suggestions on how to make sure changes to this config to allow call procvessing failover to the CCM-Subscriber? I have a publisher, in impending failure which will necessitate new drives and complete reinstall, and i need to make sure calls will still be processed by the CCM-Sub, thanks
Exisiting gateway config:
Current configuration : 3877 bytes
version 12.3
hostname PSTN_Gateway
boot-start-marker
boot system flash c1700-ipvoice-mz.123-8.T.bin
boot-end-marker
enable secret 5 $1$ZkZf$OJQS/IrGNGyBH.AyIF5P10
tdm clock T1 0/0 both export line
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
voice-card 0
voice-card 1
voice-card 2
no aaa new-model
ip subnet-zero
ip cef
ip tcp synwait-time 5
no ip domain lookup
no ftp-server write-enable
isdn switch-type primary-ni
ccm-manager redundant-host 192.168.10.1
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 192.168.10.1
ccm-manager config
controller T1 0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface FastEthernet0/0
ip address 192.168.10.4 255.255.255.0
speed auto
interface Serial0/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.213
no ip http server
control-plane
voice-port 0/0:23
voice-port 1/0
timing hookflash-out 50
voice-port 1/1
voice-port 2/0
voice-port 2/1
mgcp
mgcp call-agent 192.168.10.2 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer cor custom
dial-peer voice 10 pots
application mgcpapp
port 0/0:23
dial-peer voice 99910 pots
application mgcpapp
port 1/0
dial-peer voice 99911 pots
application mgcpapp
port 1/1
dial-peer voice 99920 pots
application mgcpapp
port 2/0
dial-peer voice 99921 pots
application mgcpapp
port 2/1
line con 0
line aux 0
line vty 0 4
password cisco
login
line vty 5
password cisco
login
line vty 6 15
no login
end
Solved! Go to Solution.
01-27-2009 12:26 PM
In this case, your gateway will stay registered when you take the publisher down.
Now, if calls will still be processed will make sure that the phones that you're calling are available and that they are also registered on the sub.
But from a gateway perspective - you shouldn't have a problem.
hth,
nick
01-27-2009 10:32 AM
Hi James,
You should be set.
This command:
Is what will allow you to fall back to the SUB/PUB.
You can do 'show ccm' and see what state this CUCM is in.
hth,
nick
01-27-2009 11:07 AM
Sorry, I forgot to say that 192.168.10.1 IS the PUB, 192.168.10.3 is the sub. So, if I change that to read ccm-manager redundant-host 192.168.10.2, i should be ok?
01-27-2009 11:16 AM
Here is the output of the show ccm: won't I need to add something for MGCP fallback, or no? If I read this correctly, 10.2 (the sub) is the active ccm-manager, and redundant host is the Publisher at 10.1, which I need to rebuild from scratch, SO, I am assuming then, that according to the current config, when the Pub is down being rebuilt, calls will still process?
PSTN_Gateway#show ccm
MGCP Domain Name: PSTN_Gateway
Priority Status Host
Primary Registered 192.168.10.2
First Backup Backup Ready 192.168.10.1
Second Backup None
Current active Call Manager: 192.168.10.2
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 17:34:41 UTC Mar 31 2002 (elapsed time: 00:00:11)
Last MGCP traffic time: 17:34:41 UTC Mar 31 2002 (elapsed time: 00:00:11)
Last failover time: 19:13:41 UTC Mar 11 2002 from (192.168.10.2)
Last switchback time: 19:15:11 UTC Mar 11 2002 from (192.168.10.1)
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 192.168.10.2
Current Link State: OPEN
Statistics:
Packets recvd: 53744
Recv failures: 0
Packets xmitted: 46710
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, port 0
Configuration Auto-Download Information
01-27-2009 12:26 PM
hth,
nick
01-27-2009 12:36 PM
thanks, I did a test by shutting down the pub and had no issues, looks like I can now proceed with inserting new drives in the pub and start the rebuild from scratch (install OS, patches, CCM, etc)
