Adding vlan to VACL
Jan 27th, 2009
Currently we are filtering data on vlan 233 and 237. Want to add vlan 321 to filter.
Here is my current config:
vlan filter Servers_IN vlan-list 233,237
My question is can I just add the vlan to the filter like this:
vlan filter Servers_IN vlan-list 233,237,321
Or do I have to remove the filter and then rebuild it?
Mohamed Sobair Tue, 01/27/2009 - 12:01
Besides adding vlan 321 to the Vlan Filter list, u need to have additional config In (Vlan Access-map) configuration, The modified config should contain new ACL statment and its action should whether be Forwarded or denied.
meadman Tue, 01/27/2009 - 12:06
I have the vlan access-map:
vlan access-map Servers_IN 10
match ip address Servers
action forward capture
The acl does include the ip addressing.
And I will add the vlan to my capture switchport.
Just wanted to verify if I could just add the vlan to the filter list or if I had to delete it entirely and then recreate the filter list with the 3 vlans I want to use. I'm thinking I can just add but wanted to double check.
