Can't Fax Local; Can Call
Jan 27th, 2009
We have a problem at one of our customer sites where they can call locally, but not fax. The faxes are connected directly to the gateway via FXS ports, and the PRI is connected in the same gateway. It is h.323 and we have all the dialpeer statments we need. We can also call out using a phone, but not using a fax. Running a debug ( dialpeer debug and isdn q931 debug) we get this we they take a fax off hook:
PRI_2811#
*Jan 27 19:55:07.497: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore: Match Rule=DP_MATCH_PORT;
And then nothing. They dial 6 digits, then they hear a busy signal.
Any ideas on what could be causing this?
Nicholas Matthews Tue, 01/27/2009 - 14:32
When you go offhook and dial numbers with an analog phone and offhook with a fax machine, there should be 0 difference.
Can you try a normal voice call with the fax machine? Most allow this.
Something else is going on.
hth,
nick
CleverDrake Wed, 01/28/2009 - 05:59
I am sorry, I was unclear before. We can dial local with VOIP phones, but not the faxes. They do not have an analog handset, and I know that that would be the best test. I just wanted to make sure that the config was correct and that this should work. The number they are calling is: 419-542-XXXX.
Here is the dialpeer config:
dial-peer voice 1 voip
description Voip dial peer for incoming calls to Subscriber 2
destination-pattern [5678]...
voice-class h323 5
session target ipv4:SUB2
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2 voip
description VoIP dial peer for incoming calls to Subscriber
voice-class h323 5
codec g711ulaw
no vad
dial-peer voice 3 voip
description VoIP dial peer for incoming calls to Publisher
preference 1
voice-class h323 5
session target ipv4: PUB
codec g711ulaw
no vad
dial-peer voice 911 pots
description Emergency 911 calls
destination-pattern [9]11
port 0/0/0:23
forward-digits all
dial-peer voice 10 pots
description Long distance dialing
destination-pattern 1[2-9]..[2-9]......
port 0/0/0:23
forward-digits all
dial-peer voice 8911 pots
destination-pattern [8]911
port 0/0/0:23
forward-digits 3
dial-peer voice 11 pots
description Local 10 digit dialing
destination-pattern [2-9]..[2-9]......
port 0/0/0:23
forward-digits all
dial-peer voice 111 pots
description INCOMING DIAL_PEER
translation-profile incoming inbound
direct-inward-dial
dial-peer voice 419487 pots
description Local Hicksville LEC
destination-pattern 419487....
port 0/0/0:23
forward-digits 10
dial-peer voice 419518 pots
destination-pattern 419518....
port 0/0/0:23
forward-digits 10
dial-peer voice 419542 pots
destination-pattern 419542....
port 0/0/0:23
forward-digits 10
dial-peer voice 419786 pots
destination-pattern 419786....
port 0/0/0:23
forward-digits 10
dial-peer voice 419881 pots
destination-pattern 419881....
port 0/0/0:23
forward-digits 10
dial-peer voice 567881 pots
destination-pattern 567881....
port 0/0/0:23
forward-digits 10
dial-peer voice 12 pots
description FAX 419-542-8534
destination-pattern [8]534
port 0/1/0
dial-peer voice 13 pots
description EL/HS Fax 419-542-8711
destination-pattern [8]711
port 0/1/1
dial-peer voice 14 pots
description PA System
destination-pattern #99
port 0/1/2
forward-digits 0
Ronald Spencer Thu, 02/05/2009 - 11:44
Most fax machines, though they may not have a handset, will have a hook/flash, speaker, or other monitor button (such that you could monitor the line).
CleverDrake Thu, 02/05/2009 - 11:52
Actually, we found the issue. We had a translation rule, and it was applied to the fax dial peers. Once we removed this (since we didn't need it on that dialpeer) everything worked fine.
Ronald Spencer Thu, 02/05/2009 - 12:15
I know this may sound odd, but have you checked line and ring voltage coming out of the FXS port? We have had significant problems in our organization with fax and other modem devices. What we discovered was a problem with line voltage. This was most often seen coming of the VG248, but we did we it on FXS ports as well. If you don't have a volt meter, I us a PE830 from Tempo which is a ButtSet and VoltMeter together.
