Need to create more than 2 channel-groups on my E1
Jan 27th, 2009
I am trying to locate a card and/or router that supports the following:
Need to split my E1 up in more than just two channel-groups.
So far I always run into the limits of only being able to create maximum two channel-groups.
Can anyone suggest a card that can handle this, and what is the minimum requirements for a router to do this.
Thanks, Oskar
paolo bevilacqua Tue, 01/27/2009 - 19:26
  • Hall of Fame,
    Founding Member
For ISR routers, the NM-CE1T-PRI, and the HWIC-1CE1T1-PRI.
