two branch of company
Jan 27th, 2009
how we connect two branch of company and provide the security ?
can any one give me any idea please
Overall Rating: 4 (1 ratings)
Joseph W. Doherty Tue, 01/27/2009 - 17:35
If you mean security in the sense to preclude someone being able to understand traffic communicated between the two sites, you would might set up an encrypted connection between the sites. This would still leave you exposed within the site.
engbandar Tue, 01/27/2009 - 19:46
how we make network between them and how masked secure for data transmit
Leo Laohoo Tue, 01/27/2009 - 19:53
There are alot of combination regarding this topic. Here's one of my favorites:
Configuring a Virtual Tunnel Interface with IP Security
How to Configure IPsec Virtual Tunnel Interface
engbandar Tue, 01/27/2009 - 20:18
if i want use the lease line to make WAN between two site.what is the best security for data
if i want use the VPN throe the internet what is the best security for data
binoyjosephstanly Tue, 01/27/2009 - 20:40
hello, if you want to use a Point to point leased line, we can encrypt the data (3DES) using Cisco IOS itself. for this i suggest you to go for security bundle routers.
2nd scenario if you want to establish IPsec Vpn again you can use 3DES to encrypt.
please rate if it helps.
Joseph W. Doherty Wed, 01/28/2009 - 04:48
If your platform supports it, would recommend AES over DES.
Cisco software encryption can quickly consume a router's CPU. Depending on intended volume, you'll likely want a hardware encryption module within the router (fyi: many of Cisco's smaller/later routers come standard with basic hardware encryption).
