CME - Set the Voicemail Pilot's Displayed Name?
Answered Question
Jan 27th, 2009
I am no CME / Unity Express expert but this seem like a simple question. I have searched high and low and can't find a solution anywhere. HELP.
First my setup:
Software
CME: 12.4(22)T / CME 7.0(1)
Unity Express: 3.1
Config
Unity VM Pilot Ext: 200
ephone-dn 300 w/ "name User 300"
ephone-dn 301 w/ "name User 301"
ephone-dn 302 w/ "name User 302"
So directory services work fine.
If I am on extension 301 and call 300 it shows:
1) On 301's phone "To User 300 (300)", and
2) On 300's phone "From User 301 (301)".
All is good so far.
Problem, if 300 is busy or does not answer and the call transfers to the VM Pilot (200), the display on 301 says "To 200"!
I want it to say "To Voicemail (200)".
I have tried to add a "Directory entry" without success (didn't think this would work). I see no where to add this in Unity, but was thinking there might be a way to add a name to a dial-peer (my VM pilot) but I don't see it.
Help?
Correct Answer by Nicholas Matthews about 8 years 5 months ago
Say your voicemail is extension 200:
ephone-dn 4
number 222
name Voicemail
call-forward all 200
222 should show up in the directory then. That would be my best guess at trying something like this. I think this is why you can configure:
telephony-service
voicemail 200
That way you never have to lookup the voicemail number because it's a hotkey on the phone.
hth,
nick
Overall Rating: 3 (1 ratings)
Correct Answer
Nicholas Matthews Tue, 01/27/2009 - 19:59
  • Red, 2250 points or more
ephone-dn 4
number 222
name Voicemail
telephony-service
voicemail 200
hth,
nick
cjbaker Tue, 01/27/2009 - 20:27
No this still just results in:
1) Flashes up for a split second the "To Voicemail (222)"
2) Then shows the final extension info of "To 200"
Any other ideas?
Nicholas Matthews Wed, 01/28/2009 - 14:36
It doesn't look like there is a native way to do this.
I looked into using SIP profiles to change the messaging, but it will only affect outgoing SIP messages, and there is no way for us to change the incoming caller ID sent in the contact field with those profiles.
If you have an account team you can ask for a feature request. It seems like it would be a trivial enhancement.
hth,
nick
cjbaker Wed, 01/28/2009 - 18:46
Thanks for the reply.
As I recall, this is easily done on Unity (assign a name to the VM Pilot). You would think it would be easily done in CME/Unity Express.
It just confusing when you dial user x on extension y and end up getting extension z on your display without a name telling what it is.
