Leased line, 1 ISDN lines Backup configuration
Jan 27th, 2009
Hi all,
I have a router with one leased line, one isdn line, where LL is the primary connection to HO, and isdn line is the backup.
now i have a DR site where in case both LL and ISDN fails to head office, it should diasl out to DR site.
How can i configure second option in the same ISDN on the same router.
Thank you all for in advance for the help.
Overall Rating: 5 (2 ratings)
Danilo Dy Tue, 01/27/2009 - 22:06
  • Blue, 1500 points or more
ISDN-PRI or ISDN-BRI? Destination IP/Port the same?
Try this;
interface Dialer0
ip address w.x.y.1 255.255.255.248 << Note: HO should be w.x.y.2/29 and DR should be w.x.y.3/29
encapsulation ppp
dialer pool 1
dialer idle-timeout 600
dialer string HO_Dialer_String
dialer string DR_Dialer_String
dialer-group 1
ppp authentication chap
ppp multilink
dialer-list 1 protocol ip list 100
access-list 100 permit ip source_ip source_mask destination_ip destination_mask
When LL to HO fails, it will trigger ISDN to dial the first Dialer_String (HO ISDN Number), if it fails it will trigger the second Dialer_String (DR ISDN Number). You decide on the routing (use floating static route).
pradeepadias Tue, 01/27/2009 - 23:00
Hi Medan,
I use different IP range in DR site ISDN, even the is it possible.?
thanks,,
Danilo Dy Wed, 01/28/2009 - 02:03
It is possible (it works for both) that configuration actually I use for ISDN-BRI with HO and DR IP range differs. The remote site of course will/should try to connect to DR site IP Address range when they could not connect to HO IP Address range. Take note that the ISDN Interface of 3 routers should use an IP Addresses in the same broadcast /29. You also have to put the destination IP Address range in the same ACL.
If its ISDN-PRI, the configuration differs a little bit.
binoyjosephstanly Tue, 01/27/2009 - 22:19
hi pradeep,
please look into this config,i think this matches your scenario.
pls rate if it helps
Binoy
