Pix 535 High CPU Utilization
Jan 27th, 2009
We have upgraded pix 535 from 6.3 to 7.2 after which we are seeing high CPU utiliztion, system has 1Gb of RAM. If we verify in the pix it says more of the process is taken by "Dispatch Unit". pls can some help on this.
--srini
eddie.mitchell@... Thu, 01/29/2009 - 07:47
  • Silver, 250 points or more
Do you have esmtp inspection enabled?
policy-map global_policy
class inspection_default
inspect esmtp
If so, I would try disabling it temporarily and see if that resolves the issue.
Hope this helps.
