Ping Problem
goutam_04
Hi, I have a network of 3 switches given in the diagram. I can ping any Ip from 2960_1 but I cannot ping even gateway from 2960_2. Can you tell me the problem. But can pingable any IPS from the Laptop connected that switch
7 Replies 7
Mohamed Sobair
Level 7
Level 7
The Link between C2960-1 and C2960-2 should be a Trunk link.
Mohamed
yes I have reconfigured as a trunk but still I cannot ping any ips from the switch. but I can ping from that Laptop.
vaisharm
Goutam,
Do you have any IP address assigned on 2960_2. If yes, then what and on which interface / SVI?
Vaibhav
No, only one loopback Interface configured. But in 2960_1 there is no IP configured except one Management Vlan with Management IP. That mean do I need to configure the Vlan 800 with IP address in 2960_2 Switch?
yes
glen.grant
How are you going to ping anything if switch 2 doesn't have an ip address on it ?
Sherwin Clarke
Just as a tip, you can create the diagram in Visio then save it as a picture/jpg file.
