CCM 5.1(3d) - XML Parse Error [4] when accessing personal directory
Jan 28th, 2009
I have recently upgraded a customer's CallManager to 5.1(3d), which in turn upgraded all of the phones to version 8.3.2. Since the upgrade, a few users who used to be able to access the Personal Address Book from the phone can no longer access it. They are requested to login, and then get 'XML Parse Error [4]' on the phone display. I have tried upgrading the phone software and locales, but the problem is still there.
This has only been an issue since upgrading the CallManager.
Mark.
irisrios Tue, 02/03/2009 - 06:15
  • Silver, 250 points or more
This issue occurs when the Prompt element contains more than 32 characters. The Prompt element can show up in many XML objects, such as CiscoIPPhoneInput and CiscoIPPhoneMenu that are supported by Cisco IP Phones. According to XML schema, the maximum number of characters contained in the Prompt element is 32. In order to avoid this issue, you need to shorten the directory name length to 31 characters or less.
m.newbould Tue, 02/03/2009 - 08:20
Thanks for your response. Is this a common issue after an upgrade?
I am running a Linux based CCM... Do you know where the files are stored and what they are called? I have not had any reason to alter these before, so it isn't something I am familiar with.
Thanks again..
Mark.
