CCM 4.1(3) to 7.0(1) upgrade
Jan 28th, 2009
When I run the upgrade assistance utility, I get the "CCM Database Settings Conflict" under the "Database Location Setting Validation"
How do I correct the database version from CCM0301 back to CCM0300.
Please see attached log from "Database Location Setting Validation_Local.log"
01-27-2009 13:40:32.308: :INFO:===============================================
01-27-2009 13:40:32.308: :INFO:====== Database Location Setting Module =======
01-27-2009 13:40:32.308:dBConnChck:INFO:Verifying dBconnectionX SERVER entry matches local hostname / IP address
01-27-2009 13:40:32.339:dBConnChck:INFO:Accessing regKey SOFTWARE\Cisco Systems, Inc.\DBL
01-27-2009 13:40:32.339:dBConnChck:INFO:String Value='Path', Data='C:\Program Files\Cisco\bin\AuPair.exe'
01-27-2009 13:40:32.339:dBConnChck:INFO:String Value='DBConnection0', Data='DSN=CiscoCallManager;SERVER=ZACDCCM02;DATABASE=CCM0300;Trusted_Connection=yes'
01-27-2009 13:40:32.339:dBConnChck:INFO:Extract SERVER name from DBConnection0
01-27-2009 13:40:32.339:dBConnChck:INFO:NodeName is ZACDCCM02
01-27-2009 13:40:32.339:dBConnChck:INFO:compare t_strLocalName [ZACDCCM02] & t_strNodeName [ZACDCCM02]
01-27-2009 13:40:32.339:dBConnChck:INFO:Found a match between local name and node name.
01-27-2009 13:40:32.339:dBConnChck:INFO:Launch dBConn0Chk.exe process
01-27-2009 13:40:32.339:dBConnChck:INFO:(dBConn0Chk.exe will log it's own messages below)
27/01/2009 13:40:32:dBConn0Chk:INFO:===============================================
27/01/2009 13:40:32:dBConn0Chk:INFO: Retrieving CallManager version information
27/01/2009 13:40:32:dBConn0Chk:INFO: Retrieve CM version from new Registry key.
27/01/2009 13:40:32:dBConn0Chk:INFO: create temporary program files
27/01/2009 13:40:33:dBConn0Chk:INFO: Identify CCM glassHouse location
27/01/2009 13:40:33:dBConn0Chk:INFO: Identify CCM database name
27/01/2009 13:40:33:dBConn0Chk:INFO: Identify Local host name
27/01/2009 13:40:34:dBConn0Chk:INFO: Identify Local host IP Address
27/01/2009 13:40:34:dBConn0Chk:INFO: Accessing CCM glassHouse database
27/01/2009 13:40:34:dBConn0Chk:INFO: Database Access Success
27/01/2009 13:40:35:dBConn0Chk:ERR : CCM Database Settings Conflict
27/01/2009 13:40:35:dBConn0Chk:ERR : Highest CCM Database=CCM0301
27/01/2009 13:40:35:dBConn0Chk:ERR : DBConnection0=DSN=CiscoCallManager;SERVER=ZACDCCM02;DATABASE=CCM0300;Trusted_Connection=yes
01-27-2009 13:40:35.120:dBConnChck:INFO:dBConn0Chk.exe process completed
01-27-2009 13:40:35.120:dBConnChck: ERR:Cisco Unified CallManager Database Location Setting test failed!
Thank you in advance.
Sibun.
