Apache.exe caused a EXCEPTION_ACCESS_VIOLATION
Jan 28th, 2009
Hi folks!
I have common services 3.0.5 installed on win2k3 SE.
anybody know what kind of error is this?
[Wed Jan 28 11:20:05 2009] [error] Apache.exe caused a EXCEPTION_ACCESS_VIOLATION in module ntdll.dll at 001B:7C84AFB2, RtlIpv4StringToAddressExW()+38452 byte(s)
else I found a file named: crash_handler_trace
C:\Program Files\CSCOpx\MDC\Apache\logs>more crash_handler_trace
EAX=00000000 EBX=77BF1D2C ECX=FFFFFFFC EDX=00000000 ESI=77BF1D28
EDI=00000004 EBP=0012DAAC ESP=0012DA84 EIP=7C84AFB2 FLG=00010213
CS=001B DS=0023 SS=0023 ES=0023 FS=003B GS=0000001B:7C84AFB2 (0x00000004 0x00000004 0x0012DB8C 0x0012DB8C) ntdll.dll, RtlIpv4StringToAddressExW()+38452 byte(s)001B:7C83D281 (0x77BF1D28 0x7C36B4B3 0x77BF1D08 0x00000000) ntdll.dll, RtlLockHeap()+604 byte(s)001B:7C34F639 (0x0012DB8C 0x000000FE 0x77BF1D08 0x00000000) MSVCR71.dll, _crtGetLocaleInfoW()+689 byte(s)001B:00C22AAF (0x00007726 0x0012D914 0x00000000 0x0012DD1C) LIBEAY32.dll, BIO_s_file()+1119 byte(s)
Any helps would be appreciate
Leonardo
Overall Rating: 4 (3 ratings)
Joe Clarke Wed, 01/28/2009 - 08:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is most likely caused by a DLL conflict. What are the locations of ssleay32.dll and libeay32.dll on your system? What is your Path environment variable currently set to?
leorob123 Wed, 01/28/2009 - 08:31
Hi Joe,
I have..
For ssleay32.dll:
C:\>dir /s ssleay32.dll
Volume in drive C has no label.
Volume Serial Number is D403-D257
Directory of C:\hp\hpsmh\bin
10/24/2007 05:34 PM 163,840 ssleay32.dll
1 File(s) 163,840 bytes
Directory of C:\hp\hpsmh\data\cgi-bin\vcagent
Directory of C:\Program Files\CSCOpx\bin
10/24/2005 10:48 PM 159,744 ssleay32.dll
1 File(s) 159,744 bytes
Directory of C:\Program Files\Legato\nsr\bin
10/24/2005 04:53 PM 155,648 ssleay32.dll
1 File(s) 155,648 bytes
Total Files Listed:
4 File(s) 643,072 bytes
0 Dir(s) 59,012,325,376 bytes free
For libeay32.dll:
C:\>dir /s libeay32.dll
10/24/2007 05:34 PM 880,640 libeay32.dll
1 File(s) 880,640 bytes
10/24/2005 10:48 PM 856,064 libeay32.dll
1 File(s) 856,064 bytes
10/24/2005 04:53 PM 798,720 libeay32.dll
1 File(s) 798,720 bytes
Total Files Listed:
4 File(s) 3,416,064 bytes
The PATH environment variable is:
C:\>echo %PATH%
C:\Program Files\Legato\nsr\bin;C:\PROGRA~1\CSCOpx\MDC\tomcat\bin;C:\PROGRA~1\CSCOpx\MDC\Apache;C:
\PROGRA~1\CSCOpx\MDC\jre\bin;C:\PROGRA~1\CSCOpx\MDC\bin;C:\PROGRA~1\CSCOpx\lib\jre\bin\server;C:\P
ROGRA~1\CSCOpx\objects\db\win32;C:\PROGRA~1\CSCOpx\bin;C:\Program Files\HP\NCU;C:\WINDOWS\system32
;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\netsnmp\usr\bin;
Legato and nagios agent was installed after CUOM. Before... CUOM was ran.
Leonardo
Joe Clarke Wed, 01/28/2009 - 08:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is what I thought. Move the Legato Path element after all of the CSCOpx Path elements, then reboot, and this problem will go away. This is bug CSCsg29627 which is fixed in Common Services 3.0.6.
leorob123 Wed, 01/28/2009 - 09:08
Hi Joe,
thanks a lot. I took a look at bug..
Info:
In CUOM 2.1 may I upgrade common services 3.0.6?
Leonardo
Joe Clarke Wed, 01/28/2009 - 09:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
All recent versions of CUOM use CS 3.0.5. There have been some tweaks to CS by CUOM, so upgrading is not advised. Wait for a new version of CUOM to come out, and use the workaround instead in the meantime.
